CARLI BJ'S, SPYNTECH HUBS - done
U-Joint bad
low rpm/boost fueling with smarty
Decided to start a new thread because the old one is too old.
4 hours Sun, 5 hours Mon. 6 hours Tue. and 4 hours Thur. I work slowly, read instructions and think about it.
A day before you start, use penetrating oil on everything you will have to loosen.
1. Wheels off.
2. Brake calipers off
3. Rotors off. Had to tap them with a rubber mallet to break loose.
4. Bearing unit. Used the power steering (as others have done) and they came loose after a few back n fourths. The bolts (4) - used a breaker bar and a small cheater. No problem.
4a. Spindle nut - used 3/4" drive and a 3' cheater - no problem.
5. Pulled the axels
6. U joints were not fun. Used a C press from Mechanics Tools. Worked well. The problem is the U joint yoke is rounded on the outside - hard to keep a receiver in place while pushing the bearing out. Tried a hammer with no luck, in fact I pinched the yoke a little. The U joints from Spyntech are ground flat on the outside - much easier to work with.
7. Ball joints. As expected they require a little work. Tighten the press real tight then wack the the bolt a couple of times then tighten the press again, etc. Drivers side was a little different than the passenger side. On the passenger side the press bolt was rubbing against the upper ball joint holder so bad I had to improvise to get the lower out.
9. The upper BJ hole on the drivers side was not perfectly round. Did a little sanding and finally go it started straight enough to start the BJ . Lots of push with the press and a few hammer wacks.
On the passenger side I wrapped some course emery cloth around a 1 3/4' hole saw attached to an electric drill and smoothed/opened the holes slightly. The ball joint hole appear to be 1. 9" and the joint are 1. 92" The ball joints still went in hard but much easier.
10. DO NOT pump grease into the joints until you feel resistance on the pump. The studs on the BJ,s WILL NOT move - period. Had to remove a tad of grease from the top and remove the zerk on the lower to bleed off the pressure. Then I could install the steering knuckle.
11. Putting the lock outs together - no problem. EXCEPT, Spyntech uses a spindle nut with a small pin sticking out which you torque to 50# then back off 1/4 turn, then a ring with a lot of holes one of which is suppose to go over the pin. The locking ring goes in ONLY one way. If one of the holes lines up with pin - great. If not you have to fish the ring back out and move the spindle nut ever so slightly - didn't line up - try again. All the while your hands are covered in grease. Finally I took a chisel and marked the spindle where the closest hole was to the pin and moved the spindle nut to that position. Wow, it worked. Then you install the outer spindle nut & torque to 150#. You have to reuse the 4 bearing assembly bolts you removed earlier. They must be cut to 1. 8" using a small cutoff wheel. I marked each bolt to 1. 8" and screwed them into the old bearing assembly until the mark just came out. Then using the bearing assembly as a guide and holder made the cuts. Unscrewing the bolts (real easy - fingers) helps clean the cut threads. The rest is straight forward.
Took it out for a drive and everything seems OK.
Hey, CUMMINZ, I would like to see it to. Have not been putting very many miles on the truck lately. Filled it up a week n half ago, last fill up was 3/1. It will take at least 5 tanks to get an idea. Probably a lot less than 5 months tho.
Will post results as soon as I get something meaningful.
Bill
As to the locking ring with the holes... used a lot of them in the past... every one I ever saw was able to be flipped over... best system in my opinion... wish dynatrac supplied it with there kit... what made this one only go in one way????
Would like to know if you really see an increase in miliage.
Me to!!! A ball park would be great
I'll take a picture and see if I can figure out how to post it. Looks like they stick out about 2 -3". Used a 4 1/2" hole saw to cut the hub cap.
Locking ring has a tab which must fit into a grove in the spindle. This grove keeps the ring and inner spindle nut from turning when you torque the outer nut to 150#. Didn't think of turning the ring over. The way it is stamped it was easier to slide in with the smooth edge going in. The space between the holes on the locking ring is about the diameter of 3 holes, so it might not have made a difference but sure would have been worth a try. Had to use a stiff piece of wire with a hook on the end to fish the ring out - no room for fingers.
As I said earlier, it will take a few tanks of fuel before any meaningful numbers can be generated. Will post them as soon as get them.
Bill
Spyntech on a dually looks like the following:
I did mine around 10K+ miles ago and did get a mileage increase. I got about 1. 5 MPG greater, easier steering, better tire a wear, and really like the 2WD LOW :)
Cheers.
Bill
As to the locking ring... . the holes are usually not equi-distant (off-set) from the tab that is on the inside... flipping over gives you another option... . versus just going to the next hole... .
D6e I really appreciate the info on the locking rings. Wish I'd thought of it. At some point in the future I'll have to re-grease the bearings or inspect them before our trip to Alaska this summer. Will make the re-install much easier. Thanks again.
Bill
