Im going to build a carport over the concrete slab NOT attached to the garage "Free Standing" on the far side I can have several Vertical support poles because they won't be in the way to access the garage. The near side is where I want a clear span so incase I want to drive into the garage I can without poles obstructing the path. The clear span from almost touching the garage to the end of the slab is 36 ft the width of the slab is 27ft. All thats going on top to be supporting the roof is 2x4 roof trusses and some 3/4 in OSB plywood to attach the metal roof to.
At 36ft its a pretty decent distance to be spanning without sag. In the picture the run-in shed in the background they sistered 2x10 and a 2x6 to another 2x10 and 2x6 alternating the placement of the 2x6 from top to bottom on opposite sides. was wondering about your ideas ???
