carryout ladder mount winegard
what are some of the steepest grades in N. America??
BF Goodrich 235/85 16 Tire Recall!
I have a UDC ( universal docking center ) on our coach that I have all the hook ups in. You could partially extend your slide and run the wires through the seal and then finish extending the slide.
I ran my ant. wires in through the liner behind where the water hose hooks up, one goes up through the floor into the cabinet where the TV is and the other one goes across through a storage space and comes up to the TV behind a built in dresser with drawers. I used the bulkhead type fittings at the entrance. I just have the two lines to the dish, the power goes through the coax cables. bg
my docking center is by the bed room slide,t. v. is in front room slide. going from rear of tralier on top of the ladder were mount is at to front room slide were t. v is. how do i bring wires in.
One side of my TV/Entertainment center is located next to an outside wall.
I modified a double Coax input receptacle cover plate to hold a 12V cigarette lighter receptacle and one Coax input. Then I drilled the proper size clearance holes thru the outside wall of the entertainment center and mounted it on the outside of the RV, running the proper 12V (+ and -) and the coax from the Satellite Receiver thru the cabinets etc.
Then I tied the 2 Carryout cables together about every 6 inches with cable ties. I then made and attached 6 AL 1/8 X ¾ 90* brackets to the 6 Carryout Dome screws. Now I can wind up the cables around the Dome w/o it unwinding. The ends that attach to the dome are never disconnected.
When setting up the Carryout I just unwind the correct amount of cables, plug them both in and watch TV. BTW- I contacted Weingard and they said that AFTER the Carryout LOCKS onto the Satellite that as long that you DON’T move the Carryout you can disconnect the 12V end and save a little battery electricity.
richardcpoxid, That is basically what I did with mine although I just have the dish with two coax cables. All my connections are outside and all I have to do is set up the dish and plug in. bg
