I bought an electric pump two months ago and i'm finally around to hooking it up.
Do any of you have any methods for running the wiring? I probably need one relay, a battery+ and a key switched + running through a PSI switch.
Anyone have experience?
I also need a good place to get a Hobbs pressure switch that kicks at about 30 psi. I don't want the pumkp to run continuously, just supplement the lift pump when the pedal hits the floor and the psi drops.
Thanks for any help.
