2nd Gen Non-Engine/Transmission Carter lift pump help.
Engine/Transmission (1998.5 - 2002) In need of a computer for '01
Engine/Transmission (1994 - 1998) throtle linkage broke
Hi! I was wanting to know the best and easiest way to hook up the Carter Rotary lift pump. My old lift pump still works but I was wanting to add this as a back up system. Do I need to run separate wires and a switch to power the pump? Do I need to put a valve where it can be closed to switch from one pump to the other? I just need a little help. Thanks for your time.
Do a search on "Pusher Pump", and be prepared for a good days worth of reading.
There is a member, whose name I cannot remember, that has a nice detailed procedure and pictures of his setup, including valves and wiring.
