Friend of mine has a 580B Case Backhoe (early 70s?) that is spewing hydraulic fluid out the vent. I checked all the low pressure connections and tightened a few worm gear type hose clamps, but it still leaks. Only leaks when you put a load on the system; idlinig, the fluid stays put.
With the fluid coming out, there are LOTS of tiny air bubbles. WHat gives? Where should I start looking? I was thinking a return line (?), but have NO idea where to start looking. Irvin is going to ask the guy at Case Mon what gives, but was thinking there are a lot of guys here that combined, know almost everything.
THanks,
Daniel
THanks,
Daniel
