A few months ago I removed my case cover to do a KDP on my 91. 5. I simply pinged the bore opening of the dowel pin and loctited it. It was pretty secure to begin with anyhow. Which is fine with me.
Then I retightened the case cover bolts and all other bolts I could get to. I guess that would include the cam and oil pump bolts.
However I didn't attempt to get to the 5th case bolt behind the cam gear. I didn't have a bent wrench and just didn't mess with it. But its bothering me now. That and the fact I didn't remove and loctite those case bolts I did get to.
So off comes the cover again to put my mind to rest. My questions is this. I installed the new case cover seal and dust seal. Since then the truck has sat for a few months and not ran due to some other work I've been doing.
Can I remove and reinstall the case cover and just reuse the new crank seal I installed? I'd rather not replace this brand new $50 seal again when I have not even ran the engine with it. I still have the plastic tool to slip inside the crank seal for reassembly.
Thanks!!
Thanks!!
