The 3126 in the newer trucks is a HEUI engine which means hydraulicly accuated, electronicly controlled, unit, injector.
I beleve that software is about the only way to increase HP. Is it still under warranty?
You have to have factory codes to change any setting that pertains to fuel setting or engine RPM. I'm pretty sure about this, I work at a Cat dealership and will ask one of the truck guys about this to be for sure. I don't know much about the 3126 because all i deal with is the eguipment and they have not started using them there. Cat is going to do away with the HEUI fuel system, or so rumor has it. Be sure you keep your oil changed every 250 hours. hours is a more accurate way to keep track because it accounts for idle time.
I will tru to find out more monday
Adam
"POWERSTROKE THIS"
Adam Harman
95 auto red and white #6 tst , eagle alluminum wheels. Stright pipe, Still BOMBING
