i put a new fuel filter on it bleed the lines cranked it up ran ok. let it sit over night and i had a hard time cranking it. now it wont start at all. when i replace the filter i filled the housing up with diesel service fuel additive. i have bled it several times at the injectors and i am getting fuel at all injectors. i used starter fluid, soak a rag in gas held it in the air intake without it even trying to start. it has always been a hard starter due to low compression i think. it ran perfect until i changed the fuel filter. I am at a loss. how hard can it be to get the air out? should it have started on the either?
question: can i get air in the lines and still get fuel to come out at the injector lines and still not crank. its getting fuel in the engine. it ran fine until i changed the fuel filter so assume the pump is working. why wont it crank of either if its getting fuel to the engine? thanks for the help it a 87 cat d3b
