Cat filter base
Front Dif Pinion seal leak
Review: Wigidigit Block Heater Plug
Has anyone used a Cat fuel filter base 7N9519 It's the true base for the 1R0750 filter the baldwin 1311 has a smaller port for the fuel out. Wouldn't that be a restriction what's the advantage of the Baldwin base if its going to restrict?
I used this cat base it came off of a 613 with a 3116 engine I don't remember the number but I use the bigger 1r749 filter just cause although it would take the 1r150 filter also
That looks nice... but I can't quite tell from the pic ...
How did you mount it ??
TIA
Was wondering the same thing our truck has the APPS on it dont know it that would make a difference in your mount as I have seen other with the APPS and still mount it there. Also was looking at your fuel line size? How did you address that issue
I just took a piece of metal and made a template and cut it out and bent it to fit at the 4 bolt holes at the front of the head the fuel line are just push fit fittings I'll post another picture to show. I've taken the loop that goes up out of it now and made it go down by flipping the line end for end cause I thought it might be draining back. Hope this helps
I've also used the larger 1r749 just because I wanted the bigger resevoir of clean fuel and made the mount two piece because I wanted the mount for the wiring and fuel line.
Hope you didnt jinx your truck using something from a 3116... hahahaaha. .
On the serious side, are you still using the factory filter base setup with the 7 micron filter installed?
And are you using the stock lift pump???
yea I'm coming out of the factory filter with a 7 micron filter in it and the 06 has the pump in tank. and the last thing before the crp is the 2 micron cat filter I also have a pressure gauge after the filters to tell me if the filter are plugging if the pressure falls. or I guess the pump failing that's the steel braided line comeing of the tee
