Howdy!
My 1990 Celica has developed a problem and I can't tell if the problem is the catalyst or if the catalyst problem is a by-product of some other problem.
Since I took over this car from my wife, I've noticed an occasional miss, maybe only once or twice a drive, at lower rpm's as I'm accelerating through the gears. I thought that it may simply be time for new spark plugs. So over this weekend, I had the oil & filter changed, then bought some spark plugs and a new air filter.
Once I put the new plugs in (gapped and torqued correctly) the car did OK, until it got fully warmed up. It kept getting worse during the day Saturday, then I put the old spark plugs back in and it still ran cr@ppy. Later I drove it to the gas station and it barely made it, it only ran on 2 cylinders, and stunk when I got to the gas station. Then I drove it back home (2. 5 miles) and it stunk and smoked when I pulled in the garage.
I got a flashlight and looked under the car at the catalyst to see if it was smoking, and even with the flash light on the catalyst I could see it glowing red. Glowing red is not normal, is it? I wouldn't even think when a car is in proper running condition it would glow red while driving.
Here's my questions:
1) If 2 (of 4) cylinders weren't working, could the unburnt fuel be collecting/burning in the catalyst causing the glowing? Thus the problem is before the catalyst?
2) Or is this typically how a stopped up catalyst will act? Severe loss of power, and stinky, smoking, glowing catalyst. It is the original catalyst with 172,000 miles.
3) Is it possible that the new spark plugs created a hotter burn that accelerated the clog of an already clogging catalyst, and that the missing I was feeling, before the new spark plugs, was the onset of the catalyst clogging?
4) One last monkey to throw in here to confuse the subject. I cranked the car in the garage, and pulled off each spark plug wire at a time (this was before I took it to the gas station when it wouldn't fall out of a tree). While idling in the garage it had a definite miss. Pulling every spark plug wire except the #3 wire, made the miss worse. Is it just a coincidence that at idle the #3 cylinder wasn't firing?
While the spark plug wires were pulled off, I put a 5th spark plug on the pulled wire. All 4 wires with the 5 spark plug in them would arc to something metal while the car was idling/missing.
Now, I'd bet at idle, since the miss is worse, there'd be 2 spark plug wires that could be pulled and the miss wouldn't get worse (I. E. 2 cylinders not firing). But its dark and cold now, so I'll deal with it in the morning. I could sure use some help here. Sorry for the long post and thanks.
- JyRO
Y2K 2500 Cummins ETC/DEE, SLT+, 4X4, Quad, LB, Intense Blue Sport, 3. 54 LSD, rear aux. springs (camper special), sliding rear window, all options except cab clearance lights including agate leather, totally stock engine, silencer ring removed, "stealth," mod to run fogs with high beam. (20. 8 mpg @ 70 mph) Since everybody else listed their toys, I will too.
2000 Toyota 4Runner SR5 4X4, 5-speed, 3. 4L V6 (25. 5 mpg @ 65 mph)
1995 Kawasaki ZX6-R, 97 H. P. @ Rr tire, 6-speed, . 6L I-4, 410 lbs. wet
- (60+ mpg @ 65 mph, but who can do that?) (For Sale)-[SOLD]
1990 Toyota Celica STX, FWD, 5-speed, 1. 6L I4 (36+ mpg @ 65 mph)
1983 Mazda RX-7 GSL Limited Edition RWD, 5-speed, 1. 1L Wankel (For sale)
No auto trannies in my home! Just say, "No!" to auto trannies.
- JyRO
