Engine/Transmission (1994 - 1998) catalytic converter plugged ?
Engine/Transmission (1994 - 1998) ? fuel been turned up
Engine/Transmission (1998.5 - 2002) Measuring Twin Turbo Boost
95 12 valve with 360K kms, started blowing black smoke. I pressure checked the intercooler and it checks out OK. I can still get 30 + psi from the turbo but it seems slow to spool up, I am wonderingi f the turbo could be plugged, It is the original
The cats have been known to plug up never heard of a turbo plugging. Your wastegate could be stuck open.
If you have a exhaust brake thay have been known to have the poatato get stuck in exhaust pipe.
The injection pump could be going that will cause black smoke.
Bill's on the right track. I gained . 5- . 75 mpg ripping out the stock exhaust.
If in Cali, just knock the guts out of the cat, and stick it back on.
