Have a 2005 Caterpillar C7 in a GMC C8500 Chassis (volunteer fire truck). The miles are low at around 5000.
The truck has always ran fine with no real issues to speak of. It gets an annual oil change regardless of miles or hours. Upon changing oil the first few times I noticed that if I attempted to drive the truck without letting it "warm" up for several minutes it would be very sluggish with no acceleration or power. Almost like a dead pedal. But it would go a little. Just sputter and plug along, then it would wake up and be fine. Take about a half a city block to come out of this. So I'm figuring I had air in the HEUI injection system.
But recently I've noticed if the truck sits for several days, I'm getting this same situation. Had a fire call this past week and it just stumbled along and didn't have any power for about a half block. Then it was fine and picked right up and ran great the remainder of the call.
On a typical day, the truck is started, idled out the door and allowed to run at a 1200 rpm idle during truck checks. By the time you drive away it runs great.
But as stated, if you need it in a hurry, starts fine, idles out the door fine, idle for maybe 30 seconds fine....then falls flat on it's face for a short while until it finally comes out of it and runs great.
The only thing I can think of is perhaps our switch to WIX oil filters has caused some drainback issues allowing air to enter the HEUI injection system? Whereas the CAT filters never did this before? I don't know...just an idea. We've used Shell Rotella 15W-40 in the engine since new.
