Hey guys, I have a 931C track loader. There is two allen headed bolts about midways in the transmission case. What do they fasten to in side the trans? If you tighten one bolt, it also tightens up the other bolt as well. Any way one of the bolts is broke off inside. Will I have to drop the transmission to drill out the bolt or is there a trick to this?
Thankyou Shannon
92 W350,LE, 4x4, DRW ,4:10 LSD, auto,DTT converter, superior transmission shift kit, 12cm2 exhaust turbo housing, PW injectors, K&N, autometer pro comp gauges, exhaust temp, boost ,trans temp, tach, mild pump adjustments, Skyjacker softride springs in front, black & silver, running boards, stainless wheel covers,
74 Road Runner
69 Dart GTS factory 383 matching no. s
Thankyou Shannon
74 Road Runner
