CB antenna clearance prob-tech situation
air horn mounting again
My turn to Thank Bill/DTT
Looking at an upcomming installation of a CB in the Dodge, and have a delema. My shop door is about 8' tall and I don't want my antenna to bend and scrape on the roll-up door and ceiling. I have a cab high shell and have been tossing around the idea of a mount on the drivers side of it (it's fiberglass) and adjusting it down when I park inside.
Is there an automatic antenna out there for CB's? I would hate to have to invent one but might have to start looking at that avenue.
Do any of you guys have ideas?
Thanks, Steve.
98 qc, 12V, 4x4, slt laramie, 47re slushbox, 3:54 ls diff, 2YG pkg, Kelsey trailer brake control, dodge running boards, diamond plate bed rails, prime designs bug shields, silencer ring wind chime on porch, Raven cab-hi camper shell, psychotty air system, T/C lock-up switch, gutted cat, Walker muffler 22572, crome 5" tip from Kenworth stack, Isspro guages, A pillar 3 guage mount, TST #6 250/635.
Toys: 70' F250 4x4 highboy- 429cid 400+ hp on 35"BFG's(ranch truck) 64' MF 205 tractor 3cyl perkins diesel w/bucket
Why don't you just install one of those cool quick releases that are out. It's neat,1/4 turn and pull the antenna off.
-Mike
I know K-40 and Firestick both make quick releases. Have used both models before, both are excellent. The only thing i dont like about quick releases are they make it easy for thieves to steal your antenna too.
I used a fire stick fender mount and a glass 3' K-40. When I pull in the garage it bumps the trim around the door but that is all. I have a good standing wave since the coil is at the top of this antenna and get out as well as anyone else.
Scott
'01 3500 qc 5sp, 4x4 white w/ green graphics dark tint, flaps,K&N 0880 and pre filter,auto meter ultra lite boost & egt in 3 guage pillar,strait piped, tonneau,painless, Uniden Grant LT w/3' glass K-40,aux. back up lights,
'91 Regal 260 at Dale Hollow
Heetseeker_1: This same question was asked not too long ago. If I remember correctly, no one knew of an automatic retract antenna at that time. However, search the lists just to be sure. In addition, and more importantly, here are some posts by Pete Peterson from the Product/Accessories Forum. You will find a wealth of great information on CBs, antennas, and mounting options.
https://www.turbodieselregister.com/ubb//Forum3/HTML/002640.html
https://www.turbodieselregister.com/ubb//Forum14/HTML/000004.html
https://www.turbodieselregister.com/ubb//Forum3/HTML/001094.html
https://www.turbodieselregister.com/ubb//Forum3/HTML/001758.html
https://www.turbodieselregister.com/ubb//Forum3/HTML/001803.html
https://www.turbodieselregister.com/ubb//Forum3/HTML/002211.html
Great luck!!
David
2001 3500 SLT, 4X4, ETH Cummins/DEE, LSD, 3. 54, Quad Cab, Long Bed, Agate, Camper Special Group, Towing Group, Additional Body Molding on Bed, Line-X bed-liner.
"REAL TRUCKS RATTLE!!"
