I have been reading the other thread about CB's, as well as all of the past CB threads.
I have a Firestik 4' firefly antenna mounted with a quick disconnect (Firestik KH 1) and spring (Firestik SS3H heavy duty spring) and the fender mount. The spring really helps when I forget to remove the antenna before entering the garage, and the quick disconnect helps for removing for various reasons.
But when driving I notice the spring allows for a lot of swing (at least 10* either side of vertical) depending upon speed and wind velocity/direction) as well as the usual wobble within the antenna.
Does this affect sending and receiving more than a more rigid antenna (w/o spring) would? Is the propagation of the signal with a CB not that precise?
