CB antenna ????
Fumes from Aux Fuel Tank in Bed?
Dual Instrument Cluster & New Single Gauge Mount
I'm thinking of takeing the CB out of my wifes car and putting it into my new Diesel (she never uses it ). What is a good CB antenna and what is the best place to mount it. Also where to get it.
Thanks Rich
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges Apillar mount. Amsoil air filter.
I have President Dakota magnet mount (like it better than the wilson) on my truck. I does a great job. I like this set up because it gets the antenna up high. You can also swivel the stinger down when going into garages and etc. without removing the antenna.
Others are using a firestik mount made just for Ram's that mounts on the fender lip under the hood.
K40 is the best in my opinion,several mounts available,the nice thing is you can twist the unit off the base so you may go in your garage,very simple,where to buy in your area??? K40 goes with independent dealers so its hard to say,worse comes to worse ,my dad is a dealer E mail me if you like!
Kevin 2001 eth dee
Where do you run the wire into the cab with the magnet mount antenna, and not have it look cheesy?
I would like to be able to leave the magnet on all the time and twist off the antenna when necessary
Where can I get a President Dakota cb antenna and where might I see a picture of one? #ad
Terry Tucker, Terre Haute, Indiana, 99 Quadcab, 5 sp,TST New Powermax2, RV injectors, Scotty's K&N setup, Ted J's complete 4 in exhaust(No muffler or resonator), 4 Rancho 9000 Shocks, G-Tech, BD exhaust brake, Mag-Hytec diff cover, PIAA driving/fog lights, Putnam Firehawk combo 5th wheel/Gooseneck hitch, Amsoil dual remote oil filters, All Amsoil fluids, Weston one piece Brush Guard, Linex liner. Dyno results: 334 hp, 859 ft lbs
[This message has been edited by TerryTT (edited 01-31-2001). ]
If I was you, I would not use a magnetic mount due to dust getting under it and sratching the paint. I have some scratches on my roof from hitting stuff with the antenna and scooting it. If you have the west coast mirrors, you can mount the antenna on them. Or you can get the mount that hooks under the hood from firestick. As far as wire routing goes, there are rubber gromets in the door hinge. I ran my wire from the mirror mount under the hood then back around into the grommet in the hinge. There is a black fiber pannel that sits in between the front of the door and the back of the engine compartment that just sits there. The grommet has to be mutlated to get the cb wire through it, and is a b**** to get back in.
1996 2500, 4x4, 5 speed
-- email address removed -- Great Lakes TDR
PURDUE STUDENT
GO BOILERS
The President Dakota has a full rubber gasket that protects your paint from getting messed up. I bought mine from www.exportradios.com.
They have a bulletin board service also that is interesting. That is how I first found out that President Electronics was carrying antennas now. I'm not sure if they (Export Radios) have a picture of antenna, but I did find a web address on their site for this antenna, when I was trying to decide between Wilson 5000, K40 and the Dakota.
Right now I run mine over to the side (you can adjust the stinger, so it is at a right angle to the truck, that way it does not stick out past the cab) and in the side window on my Ext. Cab '96. I will be putting it to the back middle of cab and running it down and up under
the floor through a grommet.
I too have been looking. But I am leaning towards the firestick hood mount in as much as when camping I take our boat on the roof boat rack, so that nixes the roof mount!
I know it will cut down on my transmission capabilities but whatchyagonna do? B4 I had dual antennas mounted on the mirrors and it worked great, but not keen on duals again...
Any thoughts?
2001. 5 2500 SLT+, QC/LB 4x4, ETH, 6spd, 3:54 LSD, camper/tow equip. , NV241HD, Bright Silver, Snug Top, Ispro w/3 pod pillar w/tweeter, Pyro, Boost & Mag Hytec cover w/temp guage, "Plain Wrap" (no decals or emblems)
[This message has been edited by Davison (edited 01-31-2001). ]
It's too late for me to worry about scratches.
I've had a wilson 1000 mag mount for 1. 5 yrs.
I love the reception, but as I understand it, the Dakota lets you swivle the antenna down when entering your garage. Am I right on this? That's why I've been thinking about switching. That, and I bent the whip on the Wilson so bad I'm going to have to replace it.
Well, I mounted twin truckers on mine. Drilled two holes in each door in above the top hinge. Looks good, 1. 2 SWRs, and talks/receives clear as a bell. I know not too many folks will drill holes in a new truck, but...
Wiredawg
2000 4X4 SLT QC 8' bed; 6 spd, 3. 54 ; BD exhaust brake and 4" exhaust syst; TST PM2; Airlift Super Duty rear air bags; RS 9000 shocks; pyro/boost gauges in 2 gauge a-pillar mount; back preasure gauge mounted under dash; KN air filter; Brown's Welding brush/grill guard, rear bumper & headache rack; nerf bars and aluminum roll top rear cover, Warn front receiver and Hadley air horns, 20K Reese hitch.
check mine out #ad
94 2500 4x4 SLT,auto,183,000 miles,3:54,brilliant blue/silver,tst 250/635 set full forward,star wheel wide open,air box ported,pump turned up 20%,k&n,gauges,cat gutted,
2001. 5 3500 4x4 q-cab slt,auto,6800 miles,3:55lsd,brite silver,tst power max 3 adjustable,3 gauges on the a-pillar,both have 12k hitches&15k's in the beds,30ft fourwinds 5er,(MY RAMS) http://albums.photopoint.com/j/AlbumIndex?u=1360183&a=10142301
[This message has been edited by **ICEMAN** (edited 01-31-2001). ]
Iceman how does the whip mount? Could it still be mounted with a tonneau cover? Where did you come into the cab with the wire?
Thanks,
Ryan
It's hard to see, but here is a pic of my mount. It is right behind the cab on the drivers side. Made a triangle mount to fit in the corner of the bed.
Daniel McKeehan
1999 2500 QC/Short Bed/4X4 5 speed. Camper Package and of course a Cummins.
BE FOREWARNED: If you have the overhead console and trip computer with compass, you should AVOID putting a magnetic anything on the cab roof. This can create a change in the magnetic field of your roof that can only be corrected by degaussing. Of course if you don't care about the compass then, by all means, go for it! Just wanted to toss that out there incase you didn't know. Though I am finding it more and more difficult to locate a TDR member that lacks knowledge about anything to do with these beasts, cept maybe me ofcourse! #ad
2001 ETH 6spd 4X4 SLT
  • Dark Garnet Red Pearlcoat
  • A. R. E. MX Topper & Walk-thru Door
  • 3. 54 Anti-Slip Diff.
  • Trailer & Camper pkg.
  • Turbo Silencer Ring in Glove Box
  • Snow Plow Prep aka Moving to Colorado Prep
Nothin' could be sweeter than "Rammin' With My Newfys!!"
Newf Limo, darn good heads-up advice. I would have never thought twice about that... but it makes sense. I will now look for a firestick hood mount then.
2001. 5, QC, 2500, 2wd, auto, 3. 54, 4 disc, long-bed, all the stuff, heated leather, patriot blue over silver, Brolin CB Bracket, stock4now!
a real "country cadilac"
Hey Pine Sap,
If you are still looking for a fender/hood
mount, let me know. I have a brand new one in the garage. I was going to use it but it would put my antenna too high to get in the garage. I opted for a bumper mount, left rear corner. Send me an e-Mail if you can't find one locally.
Mick
<font color=blue>
2001. 5 2500 ETH/DEE, QuadCab, 4X4, SB, LSD, 3. 54, SLT+, Sport, Intense Blue PC/Agate, Tow Package, Camper Package, 'DC' Bed Cover, Sliding rear window. Totally STOCK!!
On Order 4/28/00
Arrived 9/14/00 !!
My Truck
[This message has been edited by Mick2500 (edited 02-04-2001). ]
Pine Sap, if your in town holler, I fill in two days a week in the local CB shop so we might be able to help you out. Also keep an eye on the "Local and regional events" we are trying to get together the 17th of every month. Last month we all met at Wilburs in Goldsboro. Maybe if you have time you will be able to join us. Pete
the guy w/the 102'' whip its rg58
another coax is rg8x bigger, but the line
loses on 27 mhz are to small to notice unless you run 200' of the cheap stuff
stay with belden or carol coax
length doesnot matter , this is a thing cb ers think,
any of you guys want a free coax that the best for the $$$ very litter loss at 27. mhz
i use it on vhf 144 mhz its 72 ohm
not 50 ohm the difference will make swr
about 1/5 1 , also cber s think swr is real important to get it flat or 1/1
its not!!! try it create a 2/1 swr or even a 3/1 swr give single reports , i bet
you cant see a difference, hams back in the 50's never has swr , or had not way to check , they worked great still,
for you cb guys i run a 102 '' whip on
10 meters about 28. 4 mhz. antenna alone
no springs mounted on headache rack
swr came out about 1. /1. 5 to 1 very good
i also run out on the resonate freguency on
80 meters 3. 875 mhz when i work band edges ant swr is 4/1 so i use a real
tuner that fools radio into thinking swr is good. only radio is fooled so will not heat up 100watts signal reports with ant w/4/1 swr still the same as when on freq for antenna say at 3. 90 mhz my antenna is set for this freq. reminber its not the antenna
thats the problem w/high swr its the radio
that may decrease output . also one more thing every 3db gain = 2x power into 1/4 wave. most antenna gain is referred to a isotropoic or a 1/4 wave antenna(reference antenna) for cb 1/4 wave mobile is best if u like 102'' ant. anything shorter is a loss
antenna refered to the 1/4 wave ant(ref)
i tried expr. ran 148gtl 2 mirror cb ants
vrs ham radio on 27 mhz on recv only
ham had 102 '' on rack i cound not detect
any difference in rec. did not try xmit.
radios perf does not know brand if matls are
all good. buy what looks best and looks on yr trk. i run a 10-80meter antenna w. /coil
that moves in /out to change oper freq.
as you raise /coil closer to freq on.
recv gain goes up but actually antenna real lenght is not changeing much the electrical lenght is! good luck
bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
oh the free coax
cable tv hardline!!
anybody gets some ill tell ya how to adapt
pl259's to it this coax is 1/2 inch thick
will be over kill on cb works to good/
but free and grt for long runs
i put 100' in/out line no diff in signal reports. bill
