The CCD is the twisted pair (i believe purple & white/black tracer). If you check with key on, you should have 2. 5 volts on each with the meter grounded. Actually 2. 2 to 2. 8 volts ok.
the 2. 5 volts comes from the instrament cluster and you can check the ODBII port (DLC) under the dash to verify it is working. I don't know the pin numbers - look them up.
The next step would unplug EVERY module connected to the CCD and check for no more than 5 ohms between the cluster plug and every device.
CCD modules: air bag, abs, body timer, overhead consol, radio, ecm, pcm & cluster.
you are looking for a shorted to ground or open.
