CCV Filter
What is correct Fuel PSI for a 2005?
Tach reads less than 500 RPM at idle
Hello,
Was jsut wondering if there are any special tools to change the CCV Filter on my 2004. 5 Dodge?
Thanks in advanc efor your replies.
Once the plastic valve "cover" is removed, it is only two screws that hold the CCV in place. That being said, it DOES need to be pried out with a flathead screwdriver or prybar once the screws are removed, becuase it is a VERY tight interference fit with the thick o-ring that seals the CCV to the aluminum valve cover.
FYI-- on the 5. 9 CTD, the CCV is NOT a scheduled replacement item--it ONLY needs to be replaced if it is leaking around the valve cover or near the hoses, and MOST times those leaks can be fixed simply by replacing the o-ring or cutting back the hoses and adding small hose clamps to the connection... no need to buy the whole new filter, which is a simple baffle box to direct oil back to the crankcase.
The 6. 7 CCV is a different beast altogether, that DOES have a scheduled replacement interval.
