OK, this is about enough to get a guy worried.
Last couple days, the truck has been acting a little weird. It began with a mysterious disappearance of diesel sound over 2100 rpm. Not quite surging, just more like someone turns the clatter off and on at that RPM point. Weird, I thought.
CEL comes on. Codes are 0500, 0121, 0216, 1693 (as expected), and maybe a 1690, too.
I see the 0216 and I think-- "this is ridiculous, truck is running fine and I KNOW the pump can't be going at 40K with upgraded fuel delivery and an untapped wire. "
So I ignored the codes and the CEL went out a couple days later.
It came on again today. I had a VERY brief dead pedal issue, too, but only for a split second. Short enough to make you doubt it ever happened.
So, how could I be losing my VP @ 40K when I've always had good FP and haven't tapped the wire? I'm wondering if my tinkering with the fuel delivery didn't cause the pump to ingest some little particle it shouldn't have. But I haven't TOUCHED the fuel system in months. Why do it now?
The other wrinkle is this: I bought fuel from a local station that I have NEVER used before. I always used the truck stop, but when I read on here that an inspector cited Texaco fuels as the cleanest and best, I decided to try the local Texaco diesel.
Will bad fuel trip a 0216 code? If it could be fuel, why wouldn't it do it within the first few miles of starting the new tank? This didn't start until I already had like 75 miles on the tankful.
Aside from the momentary singular dead pedal occurence and the weird occasional lack of diesel clatter, nothing seems wrong at all. It always starts just fine, seems to have normal power, no extra smoke or anything.
Am I worrying about nothing?
Since I didn't tap the wire, can I fully expect warranty coverage??
Justin
Justin
