CEL with P1765
fuel feed 4 CP3
Want to replace FCA
LOOOONG post
1. CHECK IF THE DTC IS CURRENT
Ignition on, engine not running.
With the scan tool, read Engine DTCs.
Record the Freeze Frame data for the reported DTC.
With the scan tool, erase DTCs.
Turn the ignition off to the lock position.
Using the Freeze Frame data recorded earlier, try to duplicate the conditions in which the DTC originally set.
NOTE: It may be necessary to road test the vehicle to duplicate the original set conditions.
Did the DTC reset?
Yes >> Go To 2
No >> Go To 16
2. CHECK THE TTVA POSITIONS WITH THE AUTO ZERO FEATURE
NOTE: Each time the ignition is cycled to the on position, the ECM commands a TTVA internal calibration
procedure (autozero) to determine the zero position.
With the scan tool, monitor the TTVA position during the autozero test.
After the autozero test is completed, record the position percentage value.
Press and hold the accelerator pedal to full throttle after completion of the autozero test and record.
Subtract the TTVA full throttle value from the value recorded after the autozero test.
Is the difference between the two values greater than or equal to 48 degrees?
Yes >> Go To 16
No >> Go To 3
3. CHECK TTVA FOR SIGNS OF DAMAGE
Visually inspect the TTVA shaft for any signs of external damage or improperly mounted.
NOTE: It is not necessary to remove the TTVA to perform this procedure.
Is the TTVA damaged or improperly mounted?
Yes >> Repair as necessary.
Perform RE TRANSMISSION VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/
ELECTRONIC CONTROL MODULES/TRANSMISSION CONTROL MODULE - DIAGNOSIS AND TESTING)
No >> Go To 4
21 - 732 AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS DR
P1754-TRANSMISSION THROTTLE VALVE ACTUATOR STUCK (CONTINUED)
4. CHECK THE TTVA POSITIONS WITH THE TTVA REMOVED
Remove the TTVA from the transmission per the Service Information. (Refer to 21 - TRANSMISSION/TRANSAXLE/
AUTOMATIC - 48RE/THROTTLE VALVE ACTUATOR - REMOVAL)
NOTE: Check connectors - Clean/repair as necessary.
Properly support the TTVA and reconnect the TTVA wiring harness.
After recording the position percentage value, press and hold the accelerator pedal to full throttle and note position
percentage value.
Yes >> Repair internal transmission as necessary. Refer to the Service Information for proper repair procedures
for components related to the Transmission Throttle Valve.
No >> Go To 5
5. CHECK THE TTVA
Disconnect the TTVA harness connector
Connect a 12-volt test light between the (K314) TTVA Motor (+) circuit
and the (K315) TTVA Motor (-) circuit in the TTVA harness connector.
Monitor the test light in the following step.
NOTE: The test light should momentarily flash brightly, one time,
immediately after the ignition is turned to the on position.
Did the test light illuminate brightly one time after turning the
ignition to the on position?
Yes >> Go To 6
No >> Go To 7
DR AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS 21 - 733
6. CHECK THE (K315) TTVA MOTOR (-) CIRCUIT FOR A SHORT TO GROUND
Measure the resistance between ground and the (K315) TTVA Motor
(-) circuit.
Is the resistance below 5. 0 ohms?
Yes >> Repair the (K315) TTVA Motor (-) circuit for a short to
ground.
1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC
No >> Replace the TTVA per the Service Information (Refer to 21
- TRANSMISSION/TRANSAXLE/AUTOMATIC - 48RE/
7. CHECK THE (F856) 5 VOLT SUPPLY CIRCUIT FOR AN OPEN
Disconnect the ECM C1 and C2 harness connectors.
Measure the resistance of the (F856) 5-volt Supply circuit between the
ECM C2 harness connector and the TTVA harness connector.
Yes >> Go To 8
No >> Repair the (F856) 5-volt Supply circuit for an open.
21 - 734 AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS DR
8. CHECK THE (K314) TTVA MOTOR (+) CIRCUIT FOR AN OPEN
Measure the resistance of the (K314) TTVA Motor (+) circuit between
the ECM C1 harness connector and the TTVA harness connector.
Yes >> Go To 9
No >> Repair the (K314) TTVA Motor (+) circuit for an open.
9. CHECK THE (K315) TTVA MOTOR (-) CIRCUIT FOR AN OPEN
Measure the resistance of the (K315) TTVA Motor (-) circuit between
Yes >> Go To 10
No >> Repair the (K315) TTVA Motor (-) circuit for an open.
DR AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS 21 - 735
10. CHECK THE (K314) TTVA MOTOR (+) CIRCUIT FOR A SHORT TO GROUND
Measure the resistance between ground and the (K314) TTVA Motor
(+) circuit.
Yes >> Repair the (K314) TTVA Motor (+) circuit for a short to
ground.
No >> Go To 11
11. CHECK THE (K314) TTVA MOTOR (+) CIRCUIT FOR A SHORT TO VOLTAGE
Measure the voltage of the (K314) TTVA Motor (+) circuit.
Is the voltage above 0. 5 volts?
voltage.
No >> Go To 12
21 - 736 AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS DR
12. CHECK THE (K315) TTVA MOTOR (-) CIRCUIT FOR A SHORT TO VOLTAGE
Measure the voltage of the (K315) TTVA Motor (-) circuit.
Yes >> Repair the (K315) TTVA Motor (-) circuit for a short to voltage.
No >> Go To 13
13. CHECK THE (K314) TTVA MOTOR (+) CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT
Measure the resistance between the (K314) TTVA Motor (+) circuit and
every other circuit in the ECM C1 and C2 harness connectors
Is the resistance below 5. 0 ohms between the (K314) TTVA
Motor (+) circuit and any other circuit in the ECM C1 and C2
harness connectors?
Yes >> Repair the (K314) TTVA Motor (+) for a short to another
circuit(s).
No >> Go To 14
DR AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS 21 - 737
14. CHECK THE (K315) TTVA MOTOR (-) CIRCUIT FOR A SHORT TO ANOTHER CIRCUIT
Measure the resistance between the (K315) TTVA Motor (-) circuit and
Is the resistance below 5. 0 ohms between the (K315) TTVA
Motor (-) circuit and any other circuit in the ECM C1 and C2
harness connectors?
Yes >> Repair the (K315) TTVA Motor (-) for a short to another
circuit(s).
No >> Go To 15
15. CHECK THE ECM OPERATION
Reconnect all previously disconnected connectors.
Turn the ignition on for the period of 30 seconds to allow the ECM to
reset.
Yes >> Go To 16
No >> Using the schematics as a guide, check the Engine Control Module (ECM) pins, terminals, and connectors
for corrosion, damage, or terminal push out. Pay particular attention to all power and ground circuits.
If no problems are found, replace and program the ECM per the Service Information. (Refer to 8
- ELECTRICAL/ELECTRONIC CONTROL MODULES/ENGINE CONTROL MODULE - REMOVAL)
21 - 738 AUTOMATIC TRANSMISSION - 48RE - DIESEL - ELECTRICAL DIAGNOSTICS DR
16. INTERMITTENT WIRING AND CONNECTORS
The conditions necessary to set this DTC are not present at this time.
Use the Freeze Frame Data to help duplicate the conditions in which the DTC originally set. Pay particular attention
to the DTC set conditions, such as, VSS, MAP, ECT, and Load
Using the schematics as a guide, visually inspect the related wiring harness. Look for any chafed, pierced, pinched,
or partially broken wires.
Visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals.
Wiggle the wiring and connectors while checking for any possible open or shorted circuits.
Check for any Service Information Tune-ups or Technical Service Bulletins that may apply.
Were there any problems found?
No >> Test Complete.
Copied from the 2005 dodge manual
JApol,
Thanks for the post. This is way beyond me, since I don't even do my own maintenance, I just pay the man. Use to do maintenance when younger since it was cheaper and I couldn't always afford the man's cost. Took the truck in for the 30k service this morning and told them about the CEL.
Thanks again.
The problem was fixed by the dealer under warranty. It was the Auto Trans Throttle Actuator Valve. They also reprogrammed the PCM per TSB 1802207.
JApol, thanks again for the long response. As I stated earlier, this was way beyond my expertise.
No problem, I bought the Maintenance manual from Geno's when I got the truck and it has been very helpful with the trouble shooting and maintenance on my own truck. one of the Best $100 i have spent.
