2nd Gen Non-Engine/Transmission Center Foldown Console HELP!!
Engine/Transmission (1994 - 1998) I'm ready to start bombing
The bolt holding the Passenger side of my console has snapped. I need to remove the console to doctor it but I can't get the driver side hinge apart.
Can someone help me out???
Kyle, FWIW, the 98 service manual states:-
Center seat/console removal
(1) Remove bolts on driver and passenger seat inboard seat tracks.
(2) Separate center section.
On reassembly, tighten bolts to 14 ft. lbs.
If it's the lid removal that's the issue, let me know, and I will post the directions for lid removal
Nick.
As you're currently offline, I'll post the directions for lid removal:-
(1) Open console lid.
(2) Using a small flat blade screwdriver, disengage locking tabs located under the console lid trim bezel.
(3) Separate bezel from lid.
(4) Move driver and passenger seat to full forward position.
(5) Using a small drift and hammer, tap out console lid hinge pin.
(6) Separate lid from console.
Installation:
(1) Align console lid with console. Verify lid tension spring is in position.
(2) Install hinge pin.
(3) Position trim bezel on lid and snap into place.
Good luck. Nick.
I think the punch out hinge pin is what had me hung up. I'll take a pic at some point of what has me stopped for now if I still can't get it... Thanks.
