THE ADVANTAGE TO CERAMIC PADS IS... ... ... .....
THE PAD IS QUIETER. THIS IS BECAUSE THE SOUND THE PAD EMITS IS ON A FREQUENCY THAT THE HUMAN EAR CANNOT DETECT.
THE PAD IS CLEANER. REASON BEING..... THE CERAMIC MATERIAL, WHILE IT STILL CREATES A DUST, IS NOT BLACK IN COLOR(CARBON) IT IS BROWN.
THE PAD TRANSFERS HEAT BETTER. BY HEAT TRANSFER THRU THE CALIPER, THE AMOUNT OF HEAT REATINED IN THE PAD AND ROTOR IS REDUCED THUS IMPROVING BRAKING AND PAD LIFE.
AS A SIDE NOTE TO THIS... . DO NOT USE ANTISIEZE ON THE BACK OF THE PADS OR WHERE THE ROTOR MATES TO THE HUB. ANTISIEZE RETAINS HEAT WHICH REDUCES PAD LIFE, INCREASES THE CHANCES OF ROTOR WARPAGE, AND COMPROMISES BRAKE PERFORMANCE.
CERAMIC PADS ARE NOT A GOOD CHOICE FOR HD APPLICATIONS
(SEVERE DUTY, POOR DRIVING HABITS, HEAVY TOWING, ETC. )
I OWN A NAPA STORE AND HAVE QUITE A BIT OF GOOD EXPERIENCEWITH THE PRODUCT AND HAVE A TREMENDOUS REPEAT FOLLOWING FOR THE CERAMIC PAD IN MY CUSTOMER BASE.
THE RAYBESTOS PRODUCT IS VERY SIMILAR TO THE NAPA PRODUCT. MANY OTHER BRANDS ARE ONLY A CERAMIC BLEND, NOT A FULL CERAMIC PAD.
HOPE THIS HELPS... ...
TIM
