Thanks R. ebel!
The numbers come from a Cummins publication known as an Engine Data Sheet. I don't know how available these sheets are but they specify the conditions that must be met for an engine to produce it's rated power, so I would assume that they would be most useful to an engineer designing a machine or vehicle in his efforts to make sure that his design allows these requirements to be met.
This sheet gives more info than what I put into my post. One good example is that it shows the weight of the engine with flywheel housing, flywheel and electrics as 942 pounds dry and 1004 pounds wet.
Another interesting spec is one for maximum overspeed capability and that is 3750 RPM. There is a spec for friction at 2500 RPM and that is 44. 6 HP. Another interesting spec is available torque at clutch engagement RPM, 800, of 285 foot pounds.
I have had this sheet for a long time and don't remember just where it came from. As I said, I don't know how available this info is, but it it interesting to study.
Hope Smoker can use the air flow numbers to calculate what he needs for a good aftercooler!
