I have a 2004 Laredo 27RL 5th-wheel. It has two 5,000# axles, the wheels are 15" with 6-lugs, and the tires are ST225/75R-15 "D". Due to an axle problem (Keystone is going to replace the axles) the trailer has already worn out three (3) tires.
Since I need to get at least three new tires anyway, I have been wondering if it would be better, safety wise, if I had 16" tires instead of 15"?
Not knowing much about these things, I ask is it simply a matter of removing the 15" wheels & tires and replacing them with 16" wheels & tires? Or is it more involved than that?
So, I really have 2 questions:
1. Can it be done?
2. Should it be done (from safety standpoint)?
3. If the answer is yes to both of the above, then what wheels and tires do you recommend?
Thanx,
Glenn
1. Can it be done?
Thanx,
Glenn
