In the last four or five weeks, my fuel economy has dropped from 17+ to around 12 mpg (last tank of fuel). I've also noticed white smoke on start up which seems continuous. The smoke isn't real noticeable unless you are following the truck and seems more like a grayish haze then anything else. I haven't noticed it after a couple of miles or so but noticed the truck them seems to produce black smoke some on light acceleration when pulling away from a stop light. Before the mileage drop, I only noticed some white smoke when first starting the truck.
I'm wondering if I got a tank of bad fuel or if I could have introduced an air leak when I installed my boost gauge. I did a quick check for obvious air leaks but didn't notice anything that seemed wrong.
I'm thinking that I should change out the fuel filter and put in some diesel additive/injector cleaner. The fuel filter air filters were changed about 1300 mi ago.
I would appreciate any suggestions regarding what to try to figure out why my mileage dropped off so quickly.
Nearly forgot. I have a stock fuel plate, a DTT transmission with about 1100 mi on it, 4 in exhaust, and 3K gov springs and a BHAF. The check engine light is not on and I haven't tried to pull any codes.
