Just a note that I finally changed my fuel filter and I have to agree with the others who say it is a real pain to get to especially in 32* weather with a slight breeze (brrrrr) and I can see the benifets of a relocation kit, but is a doable operation after you figure out how to get your hands in there and finally acccept that you are going to spill some fuel when reinstalling the filter.
Also I had posted a question eirlier about changing the front output seal on the transfer case and had gotten it done a couple of weeks ago,all went well with the only thing being ruff was getting the seal back in while trying to get around the cross member and still see what you are doing and then getting the seal in the depth that it is supposed to be and keeping it sraight. One thing that I did notice was that the flange nut was no were as tight as it should have been it came loose with out much effort at all.
Well this is probably long enough so I will stop now.
Thanks everybody for all the help and suggestion to me and others to help getting these things done.
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar, tinted windows, 16x8 Eagle alloys series 1219, 285/75R16 Durango A/T's, stainless steel rocker panels and alluminum stirrup steps
[This message has been edited by Flatlander (edited 11-13-2000). ]
Paul
