Mike Wenrich
I'm just completing a plenum rebuild and heater core replacement on my 2004. Drained all the coolant (4 gallons) to do this work and today after refilling just two gallons the radiator splashed over. Figured I needed to start the engine to warm the thermostat up enough to open and ran the engine for over 30 minutes before getting nervous and shutting down. Took a long time to get up to just below 200 degrees and the stat never opened. The housing was warm and the heater hoses but the radiator and upper hose remained cool.
It was 54 degrees out and the fan was turning the whole time which probably increased the warm up time but is it possible an air lock is preventing the thermostat from opening? Darkness overtook me so I had to shut down anyway but it was taking a looooong time to get up to heat just idling. Looking for suggestions on what might be going on. I should be able to get two more gallons in there.
I have drained and changed anti freeze before but never to this complete degree. Thermostat and water pump are relatively new. Prior to this work all was normal. Any suggestions? I don't want to blow something up out of ignorance.
