changing back to regular oil
group ex brake
Additives - Stanadyne -VS- Lubrication Engineers
There would be no problems that I'm aware of to switch back. One thing I would like to add, use Amsoil engine flush (I believe it takes 2 cans)before running the Amsoil. Have been told by technical service that sometimes people don't get good results when swithching to a synthetic if the system is not flushed and cleaned, especially if you have a lot of miles on the engine.
Harry,
What kind of problems did you have? I'm considering going to Amsoil in my Dodge (15K miles) and my wifes Acura (115K miles).
Any help would be appreciated.
Thanks!
Eric
Eric Schultz
Y2K 2500 QC SLT+ -- Medium Bronze Pearl Coat
SS SmittyBilt Nerf Bars, flaps, X-Tang tonneau cover & Rhino bed liner
Eric,
You wont have any problems, and will like the oil. Especially on cold mornings, truck will turn easier, and start better. ( oil doesnt get as thick in cold) also handles heat better.
95-2500-ExtCab-LB-4x4-Auto-AMSoil Air Filter, Bypass Oil Filter by others, AMSOIL and Mobil Synthetics, TST 255HP and TransGO Shift kit .
Harry,
Most synthetics are compatible with oetrolium products, and I can assure you the Amsoil is very compatible with petrolium, so there would be no ill effects after using the Amsoil. However, I would think after you tried it, you would like it.
Just my opinion on the last statement.
wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
