Couple of times with the E-brake probably ok, but I know for fact it will eventually destroy the unit. I know of two such incidents first hand, and a quick call to GV, (which I did) confirms it. The clutch assembly can not handle the reverse torque an E-brake places on it. The Gear vendors unit is a clutch unit, similar to an automatic trans. The confusion might come from the fact that you can have the GV unit on truck with an Ebrake- when you engage the Ebrake, the GV unit automatically disengages and drops you into direct (When properly wired to the ebrake).
The US Gear unit however, does NOT have clutch assmeblies. It works very much like a manual transmission- changing the driveshaft rotation ratio. It is directly coupled, either in or out, so the Ebrake will not cause any problems, regardless of if it is in direct or OD.
On that note however, this is why the US gear model can not be shifted under throttle, like the GV unit can. It is also "clunky" when it fiirst engages and I did not like that (in the test truck I drove). Gear Vendors claims that the shock is within the unit and not the driveline, but I didn't care for it. Please know that I do not OWN either product, but have driven (test drive) both. I did alot of asking and searching, so I am somewhat educated on them
IF only it wasn't so much $$.
Kev
