I'm getting ready for the move out of our winter quarters to our next volunteer/host sight and was doing some catch up on the truck... .
My truck has 2 filters that I added to the fuel system when the truck was new... one is 10 micron and the other one is a 2 micron... . I was under the truck changing those... . its time... maybe 50K miles and the last time was back in 2010... their dated when I changed them last... .
So both are Fleetguard... and are from one of the class 8 applications where each is maybe 5" diameter and 10-12" high... . lots of capacity... . so I drained the water trap... can't remember when I last did that... I put maybe 4-6 oz of fuel in a jar... and the water was less than a 1/2 thimble full... . so I guess that I'm doing OK where I buy my fuel... actually as we travel, that's any truck stop... and I fill both tanks at once... .
So the primary filter actually both have a rubber washer, quad o-ring on the threads and I don't remember ever changing that quad ring... . but I screw on both filters and the truck leaks like a sieve as after I cycle the switch and than tighten the filters... I pull them both off and look at the quad ring... the quad ring on the filter housing is at least a 1/16" taller than the new quad ring in the box... I put both filters next to each other... . remember they both are from the same brand and carry the same part number the threaded portion of the filter is lower on the old filter than the new filter... I can lay a flat edge across the sealing gasket and see with my eyes that one threaded boss is lower than the other..... so I grab the new quad ring and set it next to the old one, still on the housing and can feel the difference in the two quad rings.....
Now I look at the quad rings on both new filters and they are the same with the same height from the boss to the outer gasket... . but both the old filters have the old style quad ring... .
Of course I'd pulled my drain bucket out from under the truck when I thought I had them tight... so now I've got a pint of fuel to clean up... at least its not that darn black oil from an oil change... . so in my notes that I keep for when and where I service my stuff..... trucks, cars, motorcycles, airless sprayer, part numbers, where I bought it, when it was done... . etc etc... ... . actually a great piece of software... . CARCare Desktop Edition...
Ah the fun of working on your own stuff and retirement...
