Engine/Transmission (1994 - 1998) changing head gasket got Q's
i just developed a very bad leak from my head gasket, :{ blew it? so i'm changing it.
along with valve cover gaskets/front cover gasket/front seal, etc. all still leaking(again)
what should i look out for/check/test, etc. what has to be removed to take out head.
thanks
dt :cool:
The biggest thing to look at when u get the head off is the straightness of the fire deck on the block or in other words, if its warped. Make sure its clean as spit when u put it back together. The last 2 cylinders push rods and head bolts come out threw 2 plugs in the cowl under the windsheild wipers. takes a lil bit of snaken around to get em out but youll get em.
Shane
