After I solved the turning tool fit problem tonight. I started on the exhaust springs. I found #1 tdc and changed it. I think the piston needs to be at TDC when I change each spring. I do not trust the valve seal to keep the valve up. If a valve was to drop, it would really ruin my day. My question is this. How many degrees of crank rotation is needed to bring the next cly(#5) up to TDC. I would assume 180, but at this point , I do not want to just guess.
Mark Faught, 92 ext cab service truck and a 84 crew cab one ton dually with a 91 cummins and NV 4500.
