Engine/Transmission (1998.5 - 2002) Changing out a complete '02 4wd frontend.. Need advice
Engine/Transmission (1998.5 - 2002) 18-11-99
I am going to do a 4X4 frontend/rearend swap for a guy to go from 4. 10s to 3. 54s in his truck. The rear axel is a no brainer. I want to pull the frontend in as big a hunk as possable. I am going to leave the brakes alone on each axel. Do I need a coil spring compressor? Do the front shocks limit the frontend fall on the down side? I have the Factory manuals but I'm sure one of you GENIUSES ;) ;) has figured a way to short cut the change over. Thanks, Chris
The shocks do limit how far the axle will move. You should not need a spring compressor. I put the truck on jackstands, then put a jack under the axle, unhooked the shocks, then lowered the axle down with the jack. By taking the tires off I then had enough room to pull the springs right out. Remember, you will have to unhook the trackbar, and other things so the axle will not move.
Chris you lucky dog!!!!!!! I have wanted some 4. 1 gears for a long time!! Hope all is good with you and yours, Howard.
Howard, They're not for me. I am going to do a changeout for a friend of mine that when He bought his truck, He thought He was going to tow a BIG 5ver. His WIFE changed her mind so he wants to go 3:54s as He drives the freeways alot. Had you had like years and mileage, I would have given you a call. The guy that is doing the trade is driving to my place from eastern Texas... 1800 mi one way!! Chris
