Changing Rear-end fluid-Sythetic/limtied slip issues
So I changed out the fluid in the rear and refilled with Amsoil severe gear
75-90 and 2 bottles of friction modifier for the limited slip and took truck on drive and the rearend fills like it's grabbing when turning corners.
I went into school parking lot and turned a bunch of figure 8's to work the lube onto clutches and it is still grabbing. I've put 150 + mile on it since changing fluid. Is there something I'm missing or is the rearend wore out ? Everything was fine before changing fluid. The rearend made no noise and it wasn't grabbing.
Any suggestions ?
I dont want to hurt anything by driving it like this. I even took off the rear driveline and drove around to make sure it wasn't the u-joints. the noise was still there but not so bad. I looked at the u-joints and they feel ok.
__________________
Any suggestions ?
__________________
