changing rear wheel cylinders to GM part #
Coopers Read to Replace
Detroit or PowerLock LS?
TDR FRIENDS,
I am right now removing the failed rear wheel cyclinders on my '96 Dodge 2500 4WD.
Recall reading here that a good replacement wheel cylinder is the GM part # which has a larger bore/piston, is an exact fit otherwise, resulting in improved braking performance on the rear axle.
Is this still viewed as a good move? And, what is the part # for this GM cylinder?
Thanks a lot!
DrJC
Jim Cambridge
Michigan
DrJC said:
TDR FRIENDS,
Thanks a lot!
DrJC
Jim Cambridge
Michigan
We did a '95 and my '96 and IMHO it is still a good move.
Look here:
http://www.nwbombers.com/forum/index.php?showtopic=12826
The part munber is GMC one ton are 30mm (Napa p/n 4637337 or crosses over at most auto parts)
if you do not want to read the whole thing.
