changing slide-out fabric
Enclosed Boat Trailer
How to Weigh a New Truck and 5er???
Hi all. getting ready to change the fabric on my 03 montana slide-out and will take all advice on how to do this, How do you keep the tension off the roller Thank's Don
Are you talking about the awning over the slide out...
If so, on one end of the awning, on mine its the left side facing it... . or towards the front of the truck... .
Mine has a pin that holds the spring in the position its in... . you insert a tool in one of the pin holes... pull it tighter to remove the tension on the pin... remove the pin and allow the tensioner to go a 1/4 turn looser... grab it with another tool... . remove the first and so forth...
Much like taking up the tension on the springs on a garage door...
As I remember when I installed my awnings it was 3 1/2 to 4 1/2 full turns to test it. . and tension more or less to keep the fabric tight when the slide is out... .
Hope this helps. .
