Changing transmission Fuild
Rear Axle Synthetic Lube Question
whine/whistle dont know where from
It's time for me to change my transmission fuild(30k) and on the service guide that the dealship provides it says that if you just drain the pan, 70% of the fluid remains in the converter and transmission... . but they did have a service called BD that flushed all the fluid out and replace 100% of the fluid.
So how do you guys deal with this when you go to a synthetic fluid or different brand, etc. Do you just replace the 30% or is there a trick that I need to know about?
Also what synthetic transmission fluid and rear-end(it's not a limited slip) lube are you guys using?
sounds like it's time for a new TC with a drain plug .
the flush is not that good an idea , first they don't drop the pan and change the filter , unless you want to pay close to another $100 for that service , thats what my dealer wanted , i laughed all the way out the door . anywho , if you remove the line at the drivers side front that will drain most of the fluid from the TC , drop the pan , change the filter and that gets a good percentage of it out , now would be the time for a mag hytec pan , if you don't already have a pan with a drain plug . now if you had an aftermarket TC , which is beeter than the piece of junk the factory installs , you could remove the plug and get most of it out . but then again not all aftermarket TC's have a drain plug , i didn't see one in a JRE/Pro-torque Xtreme i was spinning over by hand when checking valve lash on a friends ram ... :rolleyes:
