Hi fastmark,
I read the tap it,wack it, beat it, ideas and thought there had to be one more new way. With my luck one of the above would surely have bent a vane or something. So. . after some thought and lots of liquid wrench, what I did was to place the box end of a wrench between the bolt heads and the center part of the housing. Slowly turn each of the 4 bolts out till they contact the spacer (box end of wrench) and then go to the next. The leverage you get using the bolt threads is perfect for the job. It will start to work the hot end housing off bit by bit until it just pops loose. You can use anything as a spacer actually. Just be sure to not go too far with just one bolt as you back it out or you'll "cock" the housing in its recess. Don't forget to use some anit-seize compound on the bolts when you reinstall them.
Hope that makes sense. Let me know if not and I'll try again.
Regards, Bush'
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 101,300 Kms (63,000 mi's).
