Chargers
TST #5 plate question
ISSPRO EV pyro getting jumpy
Yes Turbo, the midwest Super Stock tractors have lots of high tec stuff the truck guys could benifit from.
I had a DT 436 IH engine in a 1086 International with a 3 charger Hypermax setup on it. It was capable of 275 psi manifold!!! Although I never saw more than 225psi. Esiimated HP was in the 1500 to 1700 HP range. The heat built up by the turbochargers is tremendous to say the least. I had a 1800 psi pressure washer pump belted to the crankshaft, a diaphram connected to a valve that would open the valve with manifold pressure. Injecting water between each stage of charging and into 6 port injectors. On a 10 to 15 second run that engine would burn about 2 gallons of #2 diesel and nearly 1 gallon of water. The 5. 9 guys are just begining to scratch the surface in water injection, fuel delivery and HP possible with the little Cummins.
COOL, this should be in the "competition" forum.
I've met some of the tractor guys around here. I like the 1066's and the D21's--and I know where there's a big Case parked in a shed... NAAAAAAH, I better stick to the trucks for a while longer. ;)
Thanks for the details.
