Charging 6 volt Series Batteries
Slide out pump not working
Considering new 5er Weight question
RBellah
I have a 6 volt battery setup in my Alpenlite 5fer. I have Six 6 volt batteries wired in series to provide 12 volt power. I'm wanting to charge my batteries during the winter by using a Battery Tender or something instead of leaving my inverter hooked up to power and running all the time.
My question is this, Do I need a 6 volt or 12 volt charger and how do I hook the thing up to all those batteries?
I know some of you out there probably have knowledge of this and I want to make sure I do the right thing.
I would try to find a 6 volt tender and charge each individually. It is better this way and you could find a weak battery easier.
Actually with 6 batteries these would be connected in a series-parallel.
You will need at least 3 maintainers with 12 volt output. I don't know of any that are 6 volt output. But they are designed to maintin a single battery. The on board convertor is designed to charge multiple batteries and probably be more efficient at maintaining and conditioning them.
one 12 volt tender is all you need but there is a better way, change your inverter to to the new style with a charge wizard. this keeps the batteries in peak shape and will last many times longer and no boiling dry.
Like CKelly1 said. Call Progressive Dynamics, and ask which converter would be best for your situation. They have a converter that has the CHARGE WIZARD already installed in it. Mine did not have the wizard and I bought and attached it to the charger. They have a desulfation system in it plus the standby charge maintainer. Check it out, There is others out there but I think that the PD is the way to go.
I have had the charge wizard for quite a few years now and love it. Picked it up from rvupgrades.com. I check the fluid level in the two 6 volt golf cart batteries each month and they usually need a little distilled water. The 5ver is plugged in 24/7.
Dave
Yep, Progressive Dynamics converter with the Charge Wizard is the way to go. One came in my '03 Lance camper from the factory. The camper has been plugged in 24/7 for all those years when isn't being used. I check the battery once every three months, or when I remember to, and it's never low on electrolyte. I usually have to add a little distilled water about every 6 months. I replaced the original battery a couple of years ago, not because it failed, but for preventative reasons. I didn't want it to become weak while on a trip.
Bill
Your 6 volt battery setup, is now a 12 volt big battery, if the battery's are fully charged, a single 12 volt battery maintainer will work just fine.
I agree with the posters who suggested a Progressive Dynamics converter with charge wizard. They are not real expensive but are an outstanding product. I installed one in my HitchHiker fifthwheel about two years ago and it has been plugged in continuously since installed.
Since I have a travel trailer I only have room for 2 six volts. In the winter I remove the batteries and put them on the bench in my unheated garage. I top up the water, hook up the cable that goes between the 2 batteries ( making it a 12v system again ) and the first of each month I put them on the a conventional battery charger for 24 hours. Doing this and also not draining them down in power when I'm camping has helped them last for years. I got 7 years out of the first set and this pair in on year 5. When it's time to replace them I will modify the tray and use four 6 volts. I have a solar panel so in the warmer weather it keeps them charged. ( It doesn't work when covered with snow )
This is a simple and cheap way of keeping them charged up. The methods described above would be great but I don't have a fancy inverter and besides in the winter I need the plug on the garage wall that the trailer gets plugged into in the summer for my block heater. :-laf Shad
Thanks for all the help! There is a lot of knowledge on the TDR RV Forum... well worth the subscription.
I am looking into Progressive Dynamics
I have a brand new one in the box identical to the one installed in my trailer two years ago but I don't want to fool with shipping.
I agree I run multi 6V batts and have a 12V tender like above if when you get home and disconnect and hook up your battery tender it looks at it as ONE BIG A** 12V. I have done it this way sense the batt's were new and have no problems. If batt's are down it just takes a LONG time to recharge Battery Tender Plus - Batterytender.com . The way I look at it the last thing I want to do is start screwing around the the electrical system on my TT it works and works fine the way it is. JMO
