My allternator died last week on my way home from work leaving virtualy blind. needing to be back up and running by the next day, I bought a new unit from napa, some generic brand but 136 amp. Put it in, put the charger on the optima red tops (about 2 years old) and took off to work the next day. Problem is, its only putting out ~11. 3 volts. I only work about 3 miles from home, so i have to put the charger on every couple of days. i'm understanding that the diodes are part of the alternator, so i'm assuming with a new alt, it shouldn't be bad diodes. Would the pcm or rectifier cause the origainal alt to go bad and a new one to not allow a full charge? Im planning on rebuiling my nippon and possibly putting it back on because its probably better than the new one, but i'm thinking that won't solve the low charge either?????
