Engine/Transmission (1998.5 - 2002) charging problem need advice
2nd Gen Non-Engine/Transmission Clear ABS fault code
Sure could use some advise
my PCM is bad and my alternator is about there. I have no voltage out of the PCM to the alt. and when I took the alt. apart the slip rings were shot. Is the mean green the best alt. and what is the best PCM thanks in advance for the help.
