On my '99 Ram 2500, when I first start the truck, the charging voltage is 12V and the "Check Engine" light remains on. If I increase the engine rpm, no change in charge voltage. Approx 30 seconds later after starting, the voltage starts going up, "Check Engine" light goes off and the system shows 14V. If I turn the truck off and restart, it does the same thing. What may be going on with any of the electronic controls that I should look at? Truck and charging system work fine after the initial hiccup.
Thanks,
Ron
Thanks,
Ron
