Had a problem last night on the way home that I would like some thoughts and advice on...
Left work, started truck, headed home, everything was normal, then "gen" light on the dash came on. Looked at ammeter and it was reading around 12 (lower white line) and not fluctuating at all. Pulled over and checked under the hood (with the engine running) didn't see anything abnormal. Got back on the road and drove the last 10 miles home with the "gen" light on and the ammeter not fluctuating a bit. Got home and backed into drive way - when I shifted to reverse the ammeter started to move again and came back up to mid-range of normal, "gen" light stayed on. Shut the truck down and checked under the hood again. Belt is OK, Generator looks OK, batteries meter at 12. 66 V (did not disconnect them from one another to test,) checked all the fuses and relays in the PDC and they looked OK. Restarted the truck and everything seems normal - no "gen" light and ammeter moving as normal. Checked for trouble codes with the ignition key method and got: 12,47, 55. Don't understand the 12, because I haven't had the batteries disconnected in months. 47 is - charging system undervoltage, but the book says that if that code latches then the check engine light should be on. It wasn't, but is the "gen" light the same thing? Do these codes clear themselves after a while or are they latched until manually cleared? This morning everything seemed normal again. Anyone else experienced intermittent issues like this? Anything you can recommend to check? Thanks in advance for any suggestions, sorry for the rambling description.
