Guys, I am leaking coolant and experiencing warmer operating temps especially when pulling grades with a load behind me. It hasn't gotten to the point of overheating yet, but I'm assuming the warmer temps are due to the low coolant level in the radiator. 155,000 mostly easy miles on the truck. I was leaking coolant earlier in the year, so I replaced the water pump in March, and that stopped the coolant loss until just recently.
I have been all around the engine with a light and am only seeing a wet spot on the front of the block just to the left of the A/C compressor bracket. The area under the water pump appears to be bone dry, but I guess it could be running down next to the gear housing and settling at the wet spot. A small amount puddles on the ground intermittently, but not all the time. I have checked the line below the exhaust manifold and everything looks dry there. Radiator and area surrounding also looks dry.
Could this new water pump have gone bad already? Are there any other possibilities for a leak that I'm not thinking of that would settle on this area of the engine block? I need to make an 1,800 mile run to pick up a car very soon but am afraid to head out like this.
Thanks for the help!
