Chat room
Links to pics
Website unavailable
When were you trying to get in? Last night I made a mistake on a change to the code that wouldn't let anyone in for about 30 minutes between 11:00 pm and 11:30 pm eastern time. What happens when you try to get into the chat room? Do you have Java disabled on your PC? The chat room uses Java so if you have that disabled then you won't be able to use it. Also, there is a virus hoax that's out there that tells you to delete part of the java program on your hard drive. Do a search on your C drive for jdbgmgr. exe - if you do not find that file then go here ( http://vil.mcafee.com/dispVirus.asp?virus_k=99436 ) and use their instructions to restore that file.
-Steve St. Laurent
Webmaster
Steve,
So that what happend last night, for a second I thought you had barred me from the chat room:D :D You never know maybe your boot finger was itchin';) or so I thought.
Glenn
Can you answer the questions above? If you can answer those I may be able to help you better. Just saying it doesn't work leaves me nothing to go on to try to help you.
-Steve
-Steve
