I did the cheap airbox mod last week. I had no problem moving the filter minder. I replaced the factory filter with a Fleetguard filter at about 11k. Still no problem moving the filter minder. Went to Home Depot for a toilet flange as others have used. The wife found something that worked better in my situation. The drainage cover found on the same isle as the toilet flange worked great. The drainage cover is a natural guard for large objects/animals. I attached 4" aluminum dryer hose with a large hose clamp. I had to cut a piece of plastic that only appears on the passenger side. I reused the plastic as a chaff guard to protect the frame from the aluminum.
As previously stated I always moved the filter minder when towing. After the mod the filter minder never moved. I towed the Jeep, trailer and camping supplies about 160miles on Friday/Saturday. This included a few times of heavy foot acceleration to keep the ricer's at bay. Egt's were also down 100degrees. Can't claim any mpg benefits. I averaged 14. 3mpg while towing 6000lbs at a constant 70mpg.
http://www.cascade4x4s.com/pics/2006 pics/August/Airbox/index.htm
