Check Engine Code 111
When do you replace the factory valvesprings?
Fuel Pressure
Anyone know what this code is just started up my truck and check eng. light was on. Checked the oil it was a quart low ( unusual ) added oil and did the key trick and came up with code 111 my book shows the 1st code as 112?
111 is iat sensor rationality,there is a flash to fix that concern,no biggie. You will not feel any symptoms.
Bob
