i have a second check engine light. first one was about 6 months ago. it was two things. over boost and fan clutch. truck ran fine after the light came on.
truck has 26k miles on it and is STOCK engine wise. the gauges are not hooked up yet as i have been to busy to do it. i do have a jake E-Brake.
once the light came on this time it stumbled and the jake would not disenguage. the throttle was not responsive much and it was on cruis control. i had been hammering on it a bit prior to the deal but had driven about 2 miles after i was. temp was normal along with oil being in the good zone (i know the oil pressure is a dummy gauge) and volts were 14. 5ish.
cycled the ignition a few times and did a few starts, and he is running great again. i do beat the **** out of him, but he keeps asking for more except for this time. oil is only 1k miles old and air filter is close to needing replaced. fuel filter is mid life.
ill check the fluids and levels in the AM. since it will be sunday ill drive my beater the remainder of the weekend then take the truck to the dealer on monday to have the codes ran.
any ideas? thanks.
Grant
any ideas? thanks.
Grant
